Home › Forums › Product Discussion & Questions › BeoMaster › Beomaster 1900 FM Stereo Indicator.
- This topic has 2 replies, 2 voices, and was last updated 1 year, 11 months ago by
auric.
31 December 2023 at 09:19 #51769
auric
BRONZE MemberCan someone tell me how the FM Stereo Indicator is supposed to work on the 1900?
On my particular unit, setting the switch “on” automatically turns the FM indicator light on and the tuner receives in stereo.
The light however stays on even if receiver is not receiving a station. Turning the switch “off” turns the FM indicator light off and the receiver receives in mono. I seem to recall in another 1900 that I owned that the FM indicator will flash on and off depending on whether it actually receives an FM signal.
The FM stereo indicator also stays on when in phono and tape mode.
Is this normal?
Derek
31 December 2023 at 14:55 #51770Dillen
ModeratorThe Stereo indicator should not light up when tuning between stations.
You could have a bad decoder IC.Martin
31 December 2023 at 20:51 #51771auric
BRONZE MemberThanks Martin, appreciate it as always. It’s been a long time since I owned one of these.
The butterfly tuning indicator works.
Derek
