Home › Forums › Product Discussion & Questions › BeoMaster › Beomaster 1900-2 help fixing crackly FM
- This topic has 6 replies, 3 voices, and was last updated 2 years ago by
Madelvic.
19 February 2024 at 08:31 #52916
Madelvic
BRONZE MemberI’m trying to restore a Beomaster 1900-2
The Phone and Tape inputs work fine, but the FM input on any of the 4 presets or 5th tuner is low in volume and crackles
So far I’ve changed all of the electrolytic in the Tuner and IF / Stereo Decoder (reference the Service Manual) but to no avail
Any help would be welcome – I’m basically stuck (and at the limit of my knowledge)
Many thanks
20 February 2024 at 02:59 #52917auric
BRONZE MemberHave you changed the electrolytic capacitors C201, C202, C203, (and corresponding on right channel)?
There is also a 10uf cap inside the can.
Derek
20 February 2024 at 09:07 #52918Dillen
ModeratorA bad MPX chip wouldn’t be a first.
20 February 2024 at 14:11 #52919Madelvic
BRONZE MemberThanks Derek. Yes I’ve changed C201, C202, C203 (and the C3xx) plus C23, C20, C99, C27 and recently C18 in the can though not tested it since the last change. C18 was reading about 17uF so working but well out of range. I’ve tested C15 but not changed it.
Wondering if I should change the transistors- will stress them with cooling spray first if I can
20 February 2024 at 14:13 #52920Madelvic
BRONZE MemberThanks Martin. Can do, would you recommend before transistor swaps?
20 February 2024 at 22:26 #52921Dillen
ModeratorYes, I would suspect the IC before any of the small transistors.
Put a scope to the L/R signals from the IC and you will see.Martin
22 February 2024 at 21:26 #52922Madelvic
BRONZE MemberFound and ordered a replacement IC. Update to follow
