Home › Forums › General Discussion & Questions › General Discussion & Questions › Beomaster 1500 Buzzing Fault
- This topic has 1 reply, 2 voices, and was last updated 24 minutes ago by
solderon29.
25 August 2025 at 12:02 #69086
SteveP37
BRONZE MemberMy Beomaster 1500 has suddenly and unexpectedly developed a loud buzzing noise on all channels. Anyone know the likely cause & if there’s a simple fix? Not being able to play my vinyl through it is badly affecting my morale.
Location: Merthyr Tydfil7 September 2025 at 12:39 #69447solderon29
GOLD MemberWhen you say “all channels”,do you mean that the buzzing is still there on radio?Is it still there with the volume control set to minimum?
If it’s only when you play records,does the buzzing stop when you remove the record player connector from the Beomaster?
If it does,then the grounding connection inside the connector may have come adrift?
There are two grounding connectors with B&O turntables,one to pin number two,and ‘tother to the connector metal case.
The plug comes apart,and the connectors can be checked and perhaps resoldered.
Nick
This reply was modified 22 minutes ago by
solderon29. Reason: typo
