Home › Forums › Product Discussion & Questions › BeoMaster › Beomaster 1400
- This topic has 8 replies, 2 voices, and was last updated 2 years ago by
astro.
20 November 2023 at 09:38 #50643
astro
BRONZE MemberHi! I bought two Beomaster 1400 on an advert. One of the 4 sliding knobs is broken (for bass adjustment) Anyone got a spare? Also, one of the channels only give a weak, distorted sound. I have checked the speaker and its ok. I have also cleaned the potentiometers. So I guess there is something wrong with the electronics. Anyone got a clue? Are there any common problems with these beautiful machines?
Cheers, Göran, Sweden
25 November 2023 at 10:43 #50644Dillen
Moderator26 November 2023 at 16:24 #50645astro
BRONZE MemberKnob here. The missing channel could be caused by one or more dead capacitors. Martin
Thanks Martin! The big electrolytic capacitors were all leaking, so I ordered some new ones. See if I can order that sliding knob also. Another thing that is broken is the flywheel for the tuning. Theres supposed to be a connecting plastic cog which has disintegrated. I guess that one is unobtainium.
Ill get back with a report if the new capacitors did any good.
Cheers, Göran
26 November 2023 at 18:53 #50646Dillen
ModeratorThe broken tuning part is (was) merely a friction clutch.
Beomaster 1400 (M/K) was produced in the late 1960s, and since 1980 there were no more working clutches. They had all disintegrated due to the choice of material.
Luciky, the tuning will work fine none-the-less, – just without the flywheel effect.Martin
30 November 2023 at 21:19 #50647astro
BRONZE MemberI changed the three big capacitors, and the sound is great- in one channel. Tried the different inputs too. The other channel is still weak and distorted. Could be a million things I guess, but are there any more common problems? Btw, the tuner is really good, picks up lots of stations.
Cheers, Göran
1 December 2023 at 08:21 #50648Dillen
ModeratorCapacitors, capacitors and capacitors.
3 February 2024 at 11:43 #50649astro
BRONZE MemberHi again! There is a pot (737 in the schematics) that is a bit charred. I think it is related to the channel (right) that is weak and distorted. Is it a good idea to change the caps in this area of the board?
cheers, Göran
6 February 2024 at 19:41 #50650astro
BRONZE MemberAlso, the right hand side transistor mounted on the rear heatsink gets varm.
cheers, Göran
11 March 2024 at 21:13 #50651astro
BRONZE MemberSo, a update, I changed some caps and it got the radio scale light working. Then I checked the output transistors and they seemed fine, all measured the same with the diode tester. But when I put the transistors back the radio sounded great from both channels. And the heatsink is much cooler.
Thanks Martin for the hints!
cheers, Göran
