Home › Forums › Product Discussion & Questions › BeoMaster › Beomaster 1200 FM, MW, LW lamps not working
- This topic has 2 replies, 2 voices, and was last updated 2 years ago by
Squidge1825.
25 March 2024 at 02:01 #53810
Squidge1825
BRONZE MemberHi there, I was wondering if someone could literally shed some light on a problem I have.
Neither the FM, MW or LW lamps are working on my system. The ON and Stereo lamps work, and I have swapped to bulbs round to eliminate the bulbs being at fault.
Not sure if it makes a difference but I am testing it with the button and slider panels off.
Matt
25 March 2024 at 15:55 #53811Dillen
ModeratorThe band lamps intensity depends on the signal strength.
You could have a bad antenna signal.Martin
25 March 2024 at 16:22 #53812Squidge1825
BRONZE Memberah ha ok, hmm, i might have a problem somewhere.
I have plugged in the antenna, albeit the white plastic connector, but none of the lamps even shine a small amount even after moving the tuner all the way from left to right
