Home › Forums › Product Discussion & Questions › BeoLit › Beolit 15 Faulty
- This topic has 2 replies, 3 voices, and was last updated 52 minutes ago by
pierre69.
8 August 2023 at 10:00 #48128
JamesD
BRONZE MemberMy Beolit 15 is five years old and has recently gone totally dead. I have tried the reset process described by Bang Olufsen support on their website and it doesn’t help. I contacted B&O Support and they responded that they cannot help with an Out of Warranty repair. My local authorised B&O re pair guy says he cannot get the information or parts to repair from B&O here in the UK, it would have to go to Germany. I have contacted Kose Trading and they suggest sending it to them in Denmark. Are there any repair shops in the UK that can help? Looking at EBay it would appear that quite a few units fail in this way.
17 September 2023 at 14:55 #48129PeterK
BRONZE MemberI have the same problem with a Beolit 15 of a similar age. No solution yet!
16 August 2026 at 18:20 #125025 pierre69
BRONZE MemberI know this is an old topic but I have the same problem with my Beolit 15. Completely dead, no sign of life…
I have check several things and I managed to find that the 4V from the start button only goes to the bluetooth module. I think that the start procedure is made by the module and if there is nothing, it’s the microcontroller of the bluetooth module that is faulty.
The repair is impossible.
