Home › Forums › Product Discussion & Questions › BeoLink › BeoLink Converter NL/ML
- This topic has 1 reply, 2 voices, and was last updated 1 year, 3 months ago by
Madskp.
2 January 2025 at 19:17 #62185
Steen Clausen
BRONZE MemberHi
I have an BeoLink Converter NL/ML were I have a problem.
My setup is :
Master link
Beosound 3000 (Used for FM radio and timer play on my Masterlink speakers.)
Beosound 3500
Beosound 2000 (With TAPE button)
Then I have two televisions connected with NL Beovison Avant and 11.
On my BeoLink Converter NL/ML I have added a chromcast on line IN.
I can without problems hear line in audio on my two televisions.
If I press TAPE on my bola 2000 I also get the musik from line in.
But I can’t get the sound from line in on my Beosound 3000.
What have I done wrong?
How shall I program the converter to send the line in to A-AUX on the Beosound 3000?
3 January 2025 at 13:20 #62206Madskp
GOLD MemberYou may have to change the role of the NL/ML converter. Since you mention that you can acces from the Beolab 2000 by pressing Tape it sounds like you have set it up like a A.master or AV.Master. But your Beosound 3000 is probably also an Audio master (A.master) and there can not be 2 of those on the ML side of the converter.
Therefor I suggest that you setup the NL/ML converter as source center and then assign the Line in to either N.radio (PHONO on older remotes) or N.music (Atape2 on older remotes), and the use these remote commands instead.
