Home › Forums › Product Discussion & Questions › BeoLink › Beolink Converter
- This topic has 5 replies, 4 voices, and was last updated 2 years, 1 month ago by
Madskp.
11 February 2024 at 12:03 #52704
theoz
GOLD MemberHi,
Is it possible to use the Beolink converter with an IR eye/transceiver ? the plug is provided.
If yes, i need the the Din Plug wiring
Theo
11 February 2024 at 12:17 #52705 Millemis
BRONZE Member12 February 2024 at 09:29 #52706theoz
GOLD MemberHi,
Thanks, but i need it for a Din plug.
I have the cable but the wires are black, red, yellow, white and shield,
so i don’t know how to solder my din plug
Theo
12 February 2024 at 12:05 #52707sverreh
BRONZE MemberThis is from Beolink handbook 1.9
12 February 2024 at 12:30 #52708 Millemis
BRONZE MemberWhich ‘beolink converter’ do you mean?
If you mean the ML/MCL Converter, the posted pic from sverreh is the right one.
In that case your ‘beolink converter’ – with the ir eye – is what usually is called a ‘Beolink Passive’.My post is for the ML/NL Converter.
12 February 2024 at 12:39 #52709Madskp
GOLD MemberI have the cable but the wires are black, red, yellow, white and shield
I don’t think you can rely on the colors of the wires in this case.
It might be an “unofficial” cable mounted on your IR eye, so you might have to open it up to check the placement of each wire.
Do note that there are several versions of the round IR eye shown above, and while +5V, IR and ground are compatible between the different versions the other signals are not.
Edit: The diffrent versions are shown in the Beolink Handbook (the above drawings are from that) which can be found online.
