Home › Forums › Product Discussion & Questions › BeoLink › Beolink 7000 Motor Issues
- This topic has 3 replies, 2 voices, and was last updated 8 months, 1 week ago by
Madskp.
22 July 2025 at 22:22 #67610
jacope
GOLD MemberHi all,
I just replaced the belt and batter on a BL7000, but it doesn’t want to stay open. Usually it will rise halfway and then return to flat position. Sometimes it opens fully but only for ~1 second. I don’t believe it is a belt issue as even if I help it to rise with my hand it still only stays open ~1 second.
Is there an end-stop switch like some other products with moving parts? I can’t seem to find it if there is.
I have not yet replaced capacitors, but it’s on the list.
Any ideas?
23 July 2025 at 06:51 #67623Madskp
GOLD MemberNot sure what it could be, but maybe a hint for fault finding. Does it do it both with the automatic function when you place it on a table, and when the manuel move on the setup menu is used?
If it is only in automatic mode it could maybe be related to the activation switches.
On another note belt size and tension can be very important. I was advised about the belt size in this post for reference: https://forum.beoworld.org/forums/topic/beolink-7000-belt/#post-66838
25 July 2025 at 15:54 #67816jacope
GOLD MemberI have since come to a better understanding of how the “Auto” function works. There are two buttons on the bottom disguised as feet. When you set the unit down, the button contact closes and the unit goes in the the “raised” position. When you lift the unit the contact opens, setting it to the “down” state. It is no more complicated than: Closed=Raised, Open=Down.
In my case my battery cover was bulging due to temporary wiring, so the button could only close briefly when setting it down. A temporary lift due to temporary button press. Problem solved!
25 July 2025 at 20:01 #67827Madskp
GOLD MemberGlad to hear you figured it out.
Testing stuff that is not fully assembled can sometimes introduce veird anomolies
