Home › Forums › General Discussion & Questions › General Discussion & Questions › Beolink 7000 issue. (not the usual one.)
- This topic has 4 replies, 2 voices, and was last updated 1 year, 6 months ago by
Beofile7.
19 August 2024 at 13:27 #58456
Beofile7
BRONZE MemberMy Beosystem 7000 has just come out of 6 months being laid up, due house renovation, and an issue has suddenly arisen with the Beolink 7000. Or possibly the Beomaster 7000?
The volume display is completely missing along with the wording “track.” The track number is displayed but not the wording “track nor volume.”
But when the unit is placed in it’s charger the time is displayed with no issues. I thought the little LED’s might have failed but not so.
I wonder if it could be an issue with the info not being transmitted correctly from the master 7000? I don’t have another to try it with.
Has anyone seen this before and can point me in a direction to get it sorted? Thanks.
19 August 2024 at 17:03 #58462Beofile7
BRONZE MemberA quick update…
I just noticed that when on it’s charger all the displays are correct. Until it is removed from the charger. Then the issues arrise.
So it looks like a power issue with the Beolink 7000?
29 August 2024 at 21:19 #58690mcevedy@mac.com
GOLD MemberI wonder if it needs a new battery – maybe simply does not have enough power for all the LEDs. Multicare seem to be able to fix most things – they are playing with a variety of my odd stuff and I suspect changing a battery and checking the power rails could be in order. Complex inside so unless confident, I would leave to them!
30 August 2024 at 09:11 #58706Beofile7
BRONZE MemberYes that is what I am thinking too as it was working just fine before being laid up for a few months. I have ordered a new battery which should be here next week. This must be the 4th time I have changed the battery on this BL7000 but all the previous occasions the unit went into “flashing” mode. Hence my reasoning that it was not the usual problem? We’ll see?
7 September 2024 at 11:27 #58939Beofile7
BRONZE MemberWell that didn’t work at all. New battery fitted but still the problem exists. It also is now apparent when on it’s charger.
I think I will have to hand it over to my engineer?
