Home › Forums › Product Discussion & Questions › BeoLink › Beolink 7000 – belt
- This topic has 4 replies, 3 voices, and was last updated 2 months, 3 weeks ago by
Madskp.
6 July 2025 at 15:18 #66829
Madskp
GOLD MemberI have started taking a Beolink 7000 apart to replace capacitors as it has the well known no contact issue.
When I opened it up I noticed that there is a belt from the motor to the lifting mechanism which seems a little loose although still good enough to lift remote. But since I am already disassembling the remote I might as well replace the belt.
However Danish Soundparts do not have this belt, so I am wondering if anyone else has the correct size for this belt?
Thanks I advance
6 July 2025 at 23:52 #66838billb
GOLD MemberHi,
I used 1 mm X 33mm ID round belts (o-rings) on mine and they work fine.
Good luck,
Bill
7 July 2025 at 13:58 #66842Madskp
GOLD MemberThank you very much 😀
It’s always hard to judge how much these old belts have stretched over the years
Now to find a place to source them
9 January 2026 at 18:03 #72466ChristianLJ
BRONZE MemberThank you very much 😀
I have the correct belt in stock, write me a message if still needed 🙂
10 January 2026 at 09:34 #72473Madskp
GOLD MemberI have the correct belt in stock, write me a message if still needed 🙂
Hello Christian
Thanks for letting me know. I have yet to get the two way functionality to work, so have not come to the rubber belt part yet. I will get in touch if I am going to need it
