Home › Forums › Product Discussion & Questions › BeoLink › BeoLink 7000 not moving down
- This topic has 3 replies, 3 voices, and was last updated 2 years, 11 months ago by
filip_kbh.
10 May 2023 at 09:36 #46515
jebeo
BRONZE MemberHi, I have a question regarding the BeoLink7000 which I haven’t found an answer in the manuals.
The BL moves up when touching the bottom plate and operates as normal.
However, it is not moving down at any time after I stopped touching it. ONLY if I lift up the bottom so that the 2 pins loos contact.
Any help appreciated. Thx, Jens
10 May 2023 at 10:44 #46516Die_Bogener
BRONZE MemberThere is a setup option “move”. Automatic and manual.
But this behaviour is not quite normal. Mine does not move when waking up.
Maybe the lithium Battery is going bad… BL7000 has a 6V Batterie AND a 3,3V lithium cell…
10 May 2023 at 11:33 #46517jebeo
BRONZE MemberThx.
I have switched AUTO = OFF. Now I can at least manually control the movement.
10 May 2023 at 12:18 #46518 filip_kbhBRONZE MemberWhen in Auto mode, it will only move the upper panel down when you lift it up from the table. If you want it to lie straight on the table you must do it manually.
