Home › Forums › Product Discussion & Questions › BeoLink › Beolink 5000 keeps reverting to one way mode.
- This topic has 5 replies, 3 voices, and was last updated 1 year, 4 months ago by
matador.
29 December 2024 at 19:07 #62043
matador
ModeratorHi everyone,
I use a Beolink 5000 in one way mode to control things in my office.
Unfortunatly the remote seems to regularly return to two way mode making it complicated to use.
At first I thought it was a problem with battery contact: loose batteries cut power tus reverting it to initial state (two way).
I secured battery contacts si I think I can rule out this cause.Do any of you experience this or have any idea?
Thanks.
29 December 2024 at 19:31 #62044 YannChrisGOLD MemberHi,
Mine has the same problem from the beginning, with a 2 way Beovision and a 1 way Beocenter.
I also explored the “batteries way” with no success. I think it’s software-related.
The TV is gone, but the probem remains and I never found any way to solve it, unfortunately.
So if someone can help, it would be greatly appreciated.
Yann.
31 December 2024 at 10:59 #62085 skolesenGOLD MemberI’ve seen that when using normal non-rechargeable batteries on the Beolink 5000s that I’ve renovated. The minus pad is often to small and create bad contact in the battery bay, especially the midle one. . Problem was solved by using rechargeable batteries (Ikea LADDA) where the minus pad is bigger.
Hope this can help.
/steffen
31 December 2024 at 17:03 #62097 matador
ModeratorThank you Steffen,
I use Ladda batteries: I like to keep it all “nothern”!
And I’ve add aluminium foil pads to secure the contacts.
31 December 2024 at 17:05 #62098 matador
ModeratorI’d like to add tha I’ve some Beo 4 that exeperience similar issue: not reverting to one way of course, but stopping to work after some time. Dont know if it could be related.
10 January 2025 at 13:30 #62493 matador
ModeratorMaybe a hint,
Because of my setup (two Beosound Daisy-chained) and mu usage (once one, once the second, once both…) I need to fiddle with the “LINK” prefix key.
Sometimes when I need to shut all down I make a long press on the “Stand-by” key that turn all off.I wonder if this do not make the remote revert to two way mode., because to change the mode, process say you must turn off the remote with a long press on “STBY”.) barely similar to taking the batteries out and in the remote.
