Home › Forums › Product Discussion & Questions › BeoLink › Beolink 1612 ??’s.
- This topic has 8 replies, 2 voices, and was last updated 2 years, 3 months ago by
striker27.
10 December 2023 at 04:27 #51136
striker27
BRONZE MemberAt present I have a Beosound Overture connected to a Beolab 3500 and two Beolink Passive Amps. I was hoping to be able to get some of my audio collection from my Mac Mini to play on the system. Would I be able to use the 1612? It has Sw 1.3 of that matters. I know I would need some cabling. Or is it more prudent to get something like a 1636?
thanks.
10 December 2023 at 08:54 #51137Madskp
GOLD MemberIf you want the music from the Mac Mini playing on the whole system you could connect it to the AUX connection on the Beosound Ouverture.
however if the AUX connection is already in use fo other equipment you can use the 1612 to get an extra AUX connection (the connector labeled AAL) that is activated with video commands (TV, V.MEM, DVD etc). This however require you do not have any B&O tv’s in the rooms as this would make conflicts in operation.
The PC input on a Beolink Active will only play music in the room with the Beolink Active, so might not be what you want.
Hope this help you on the way
10 December 2023 at 14:22 #51138striker27
BRONZE MemberI tried to use the AUX connector but the volume was very low. I was hoping using the 1612 would remedy this issue. Do I need any specific cabling??? If so where would I acquire it??
thanks.
10 December 2023 at 15:15 #51139Madskp
GOLD MemberWhen using the Aux connector the volume of the Mac Mini should be set relatively high.
You should be able to use the same Aux cable with the 1612 when used as a video source. Masterlink cable between the 1612, Ouverture and link rooms. If that also has low volume the AUX cable could be configured wrong (output instead of input)
10 December 2023 at 17:18 #51140striker27
BRONZE MemberOk that sounds possible. Where would I source the cable to go from the Mac Mini to the 1612?? I have the Master Link available.
Previously I used a Din cable with a pair of RCA’s to get sound to the Overatures AUX port That may have been the reason for the issues I faced In hindsight I see how the DIN connector configuration may be an issue in my previous attempt.10 December 2023 at 17:24 #51141Madskp
GOLD MemberIf you also have a RCA to minijack adapter you could try starting combing that with your RCA to din cable.
If not try searching for B&O Aux cable minijack and you will probably find the right one
10 December 2023 at 17:47 #51142striker27
BRONZE MemberI would like to have the system working in a manner that is easy to use. I was hoping that the 1612 or another unit would allow me to do so. Playing through the entire house is my goal. I will try searching for something with a Mini Jack to connect my Mac Mini to see if I can get an acceptable solution. I know the Din RCA Jack idea I had was a bit of a bust.
10 December 2023 at 17:57 #51143Madskp
GOLD MemberIf it turns out its a cable issue you could use either the AUX port on the Ouverture with the phono or n.music command. If you are using BEO4 remotes you will have to find this as a soft button via the LIST button.
Using the 1612’s AUX input will hower react to any Video source buttons and therefor be easier accesible.
10 December 2023 at 19:22 #51144striker27
BRONZE MemberI was thinking that the best way to do it would be to use the 1612 to make the setup easier to use in the long term.
