Home › Forums › Product Discussion & Questions › BeoLab › Beolab28 issuing constant white noise from one of the driver
- This topic has 1 reply, 2 voices, and was last updated 8 months, 3 weeks ago by
multicare.
13 May 2025 at 20:57 #65584
Yoann Yo
BRONZE Memberhi All
I’m enjoying my Beolab28 without any problem … until recently
since few hours : one of the Beolab28 is issuing a constant « white noise » from one of its driver: one of the mid range (up, right) is emitting this noise whenever the speaker is ON.
– no matter which source I’m using
– the speaker is connected to router via ethernet
– the speaker is up to date (4.1.3), and I’ve factory reset it, run Room compensation again, and unpair / repaired the stereo with the other beolab
can you please help me ? I’m very worried it could be a hardware issue ??
16 May 2025 at 15:58 #65660 multicareGOLD MemberReach out to your local service provider or store.
Allow remote support via the app.
The store/service provider will log into the speakers and check for issues along with sending a log report to denmark.
They will need to know the serial numbers of the speakers.My B&O Icons:
