Home › Forums › Product Discussion & Questions › BeoLab › BeoLab wall bracket: what sizes of screws & springs
- This topic has 4 replies, 2 voices, and was last updated 2 years, 7 months ago by
KolfMAKER.
2 January 2024 at 09:16 #51796
KolfMAKER
BRONZE MemberI got a BeoLab 3500 with an incomplete wall mount set. What I am missing (see picture) are the 2 long screws, the 2 springs and the 4 washers.
What I especially need to know is the size/specs for the long screws and the springs.
Anyone knows them?
2 January 2024 at 10:41 #51797 TignumGOLD MemberHi KolfMAKER, was hoping to find it for you in the service manual: only the screw specs are given.
The screws in the photograph appear much longer than the 32.7. Also, just two washers seem to be used. Hopefully someone can measure the springs for you.
Regards, Johan
2 January 2024 at 11:10 #51798 KolfMAKER
BRONZE MemberThnx @Tignum, this is helpful!
I think the width of the allen screw is compliant to M4. I found a screw with a fitting thread, which has a 4mm diameter.
The length of (1) I think is correct. If I measure with a fitting screw, it goes into the speaker for about 1cm. So there should be 22.7mm sticking out to hold the bracket and have space for the washers and the spring.
The bracket thickness is 4mm, each washer is 1mm, so that takes 6mm. The spring then sits in a space of 16.7mm, actually a bit less when put under pressure. So I assume the spring in an unstring condition could be like 18-20mm.
I will now start looking for those parts.`
2 January 2024 at 11:22 #51799 TignumGOLD MemberHi, with you finding M4 thread, the 6 in 6 x 32.7mm must then be the diameter of the head of the screw.
2 January 2024 at 11:24 #51800 KolfMAKER
BRONZE MemberPerfect, thanks!
