Home › Forums › Product Discussion & Questions › BeoLab › Beolab product with Beoplay V1
- This topic has 4 replies, 2 voices, and was last updated 2 years, 8 months ago by
Ben88F.
2 August 2023 at 03:04 #48027
Ben88F
BRONZE MemberDear all,
i have not found the info clearly and I have the feeling Beoplay V1 is often use as is because I do not see a lot of exemple with that TV and Beolab speakers.
I am thinking about using a Beoplay V1 + Blu Ray as input for my Beolab 5 (to replace my BS CD player and reduced number of equipment).
From the manual, it seems feasible with PL1/2/3, but I do not found example on the net, and I had contradictory info (someone told me it is not possible to connect them and an article says it might not been compatible with B&O equipment.
Would someone see any concern of doing that? Any concern sound wise? My goal is to reduce number of equipment in my living room and that TV seems to offer descent picture with accessible price on top of having powerlink plug,
Thank you
Ben
2 August 2023 at 16:04 #48028 MillemisBRONZE MemberI see no reason, why you should not be able to connect the 5’s there.
I have have been running a full 5.1 setup with my office V1/32” for many years…..no problems there.
Lots of options how to use the speakers/speaker groups….just like with other newer BV’s.
You ‘only’ have 3xPL and no WiSA.
Otherweise – if you can live with a max of 40” – no limits.I have a blu ray player and an ATV connected – and it is connected to the NL setup in the house.
I am keeping that setup as long as possible!
2 August 2023 at 20:00 #48029Ben88F
BRONZE MemberHi Millemissen.
thank you for taking the time to share your experience. This is 100% the type of feedback I as looking for.
I am not looking for a big screen so 40 is more than enough for my need. I think I will go this way then!
2 August 2023 at 20:18 #48030 MillemisBRONZE MemberN.B.
You will probably be able to find your Blu Ray player in the PUC setup (in the tv menu) in order to control it with the B&O remote.
You can configure the Speaker Groups you make, so that only the 5’s (probably set as fronts) are active with a certain source….for instance if you often use the Blu Ray player as a CD player.
If you use the Beoremote One you can use one of the MyButtons to start a given source in a given speaker setup.
2 August 2023 at 20:24 #48031Ben88F
BRONZE MemberThis is good to know. I am not familiar with B&O tv, but it seems to bring some nice functionality. A lot to discover!
