Home › Forums › Product Discussion & Questions › BeoLab › beolab penta mkIII with digital noise
- This topic has 2 replies, 2 voices, and was last updated 8 months, 4 weeks ago by
nitro2.
22 June 2025 at 12:46 #66591
nitro2
BRONZE MemberHi forum ,
i do hear digital beeps in my beolab penta’s ( the communication signals from the beomaster ) ,
Is there a way to dampen these noises ?
is this common or a sign of older-age ?
You must be logged in to view attached files.23 June 2025 at 13:33 #66608 AdamSBRONZE MemberI’ve had this issue with Beolab 8000s and it usually means you’re using the wrong type of Powerlink cable that doesn’t have the right shielding.
Steve at Sounds Heavenly will be able to advise and sort you out with the right cables.
23 June 2025 at 17:51 #66612nitro2
BRONZE Memberit is the “high quality ” 5mm double shielded cable ………………………
from a reputable seller ( not ali ) .
it does not affect my hearing experience , i was only worried about the speakers .
