Home › Forums › Product Discussion & Questions › BeoLab › Beolab Penta: how do you get to the crossover PCBs?
- This topic has 6 replies, 3 voices, and was last updated 2 years, 6 months ago by
Die_Bogener.
31 August 2023 at 08:05 #48581
klesolin
BRONZE MemberI see them in the service manual, they’re boards 14 and 15. But they don’t really tell how to get to them.
Is it just a matter of unscrewing the foot and the plastic base and then I can slide them out?
I’d like to inspect the capacitors and see if they need replacements while I have them on the bench to replace the surrounds on the midrange drivers.
31 August 2023 at 20:33 #48582Glitch
BRONZE Member- Remove amp
- Remove bottom plate
- Remove wires from crossover(s). Wires are color coded and labeled on the crossover.
- Pull hard. The boards are held in place by friction (even though it might feel like they are welded in place). The boards slide into slots in the housing. There might be tape on the board to keep it from rattling. Try not to pull on any of the crossover components.
Hopefully this makes sense. Good luck!
Glitch
1 September 2023 at 09:18 #48583Die_Bogener
BRONZE Member1 September 2023 at 09:26 #48584Die_Bogener
BRONZE Member1 September 2023 at 17:09 #48585klesolin
BRONZE MemberThank you. I had a look, the caps look OK and so do the coils. The speakers sound fine to my ear.
Do you mean physically damaged coils? How can they get damaged from within the speaker?
2 September 2023 at 12:58 #48586Glitch
BRONZE MemberHow can they get damaged from within the speaker?
I’ve always assumed that the damaged coils were a result of people pulling their crossovers to check if their coils were damaged. 😉
An alternative (more serious) explanation is that the coils break loose from a hard impact during shipping.
Glitch
2 September 2023 at 13:15 #48587Die_Bogener
BRONZE MemberShipping? Yes, that is possible.
Heat? Yes, the glue is not very stable against heat and becomes soft/sticky around 60-70 degrees C. It is not epoxy, it is something like a hotmelt glue.
I think, heat and overload can do this.
Pulling boards? Yeaaah… sure.
But most: i think the Penta was dropped during transport or by running kids/dogs/cats. Most of them had massive damages on the top plate. So there was a very hard impact…
But it can be repaired, it just needs time.
