Home › Forums › General Discussion & Questions › General Discussion & Questions › Beolab connected to WISA and Powerlink
- This topic has 9 replies, 5 voices, and was last updated 1 year, 3 months ago by
beotex.
8 November 2024 at 10:29 #60762
20cen
BRONZE MemberHi everyone,
Do you know if it is possible for a pair of beolab 18 connected to a beovision with WISA, to be also connected with a powerlink cable to a beocenter 2, or a turntable or any other device?
If yes, how is the experience?
thanks all
12 November 2024 at 11:05 #60827 tphBRONZE MemberConnecting multiple sources to Beolab 18 at the same time is possible, but only when they are all wired. They are prioritised in this order:
- Power Link
- Optical input (Toslink)
- Line input (RCA)
It’s not possible to use wireless and wired sources at the same time.
12 November 2024 at 18:58 #60838 MillemisBRONZE MemberConnecting multiple sources to Beolab 18 at the same time is possible, but only when they are all wired. They are prioritised in this order:
- Power Link
- Line input (RCA)
As far as I remember, this is only the case if you use then as a ‘standale’ pair – not if they are PL-connected to a Beovision.
12 November 2024 at 18:59 #60839 MillemisBRONZE MemberConnecting multiple sources to Beolab 18 at the same time is possible, but only when they are all wired. They are prioritised in this order:
- Power Link
- Line input (RCA)
As far as I remember, this is only the case if you use then as a ‘standalone’ pair – not if they are PL-connected to a Beovision.
13 November 2024 at 13:31 #60862 tphBRONZE MemberThere is no way to use Beolab 18 as a “standalone” pair, it always needs to be connected to a source, wireless or wired. In wired use, the aforementioned prioritisation applies.
Maybe you’re thinking of Beolab 28 instead, which do have sources built in and behave differently otherwise too?
13 November 2024 at 14:51 #6086620cen
BRONZE MemberHi,
thanks a lot for your answers
I have a beovision 11, and I was thinking of buying a pair of beolab 18.
my initial plan was to connect them with Wisa to the beovision, and also connect them to a beoconnect via powerlink, so that I can also listen to radio or spotify…
But as you said, maybe beolab 28 would be a better fit for such use case.
thanks again
14 November 2024 at 20:49 #60941 MillemisBRONZE MemberThere is no way to use Beolab 18 as a “standalone” pair, it always needs to be connected to a source, wireless or wired. In wired use, the aforementioned prioritisation applies. Maybe you’re thinking of Beolab 28 instead, which do have sources built in and behave differently otherwise too?
Certainly I do not ‘mistake’ the 18’s for the 28’s!
But my explanation maybe – for you – was a bit unclear…..sorry for that.
The BL18’s are a pair of speakers!
Also see my post in this thread
….which also contains a link to a posting on Geoff Martins website about the 18’s.
13 May 2025 at 16:51 #65582 beotex
BRONZE MemberRelated but different question. Can you have two Beolab 8’s (1) stereo paired for music sources, and (2) WISA connected to a Beovision for TV sources? I don’t want to wire anything.
I think the answer is no, but maybe someone has been able to achieve this scenario.
13 May 2025 at 21:21 #65585TinusAMS
BRONZE MemberI had the 8’s in wireless stereo pair and then connected via Wireless Powerlink to my Theatre. That worked absolutely fine. 28’s as well.
15 May 2025 at 19:31 #65633 beotex
BRONZE MemberThanks – I’m still having challenges but glad to know it’s possible.
