Home › Forums › Product Discussion & Questions › BeoLab › BeoLab 8002, via Line-IN: not going back to stand-by
- This topic has 0 replies, 1 voice, and was last updated 5 months, 2 weeks ago by
KolfMAKER.
Viewing 1 post (of 1 total)
13 October 2025 at 16:40 #70403
KolfMAKER
BRONZE MemberHi all,
I have a pair of BeoLab 8002 that I want to use with an external DAC (ESS 9023 Sabre chip) > connected via Line-IN on the 8002, with a shielded cable, and of course set the foot switch to the right position.
Problem:
When I stop the music, the 8002 does not switch back to stand-by; the LED remains green and the speaker stays powered ON.
What I’ve tried / setup details:
- The DAC is AC-coupled and provides a typical line-level signal (~0.9-1 V RMS)
- Standard shielded cables, 1 meters in length
- I have put 47K ohm resistors between Pin 3 and GND, end between Pin 5 and GND > no result
- I have set the volume output of the DAC to zero (to see if this could ‘silence’ the signal > no result
- Changing the DAC to different audio source; iPhone via same cable > the 8002 does switch back to stand-by correctly
I think the fact that the DAC is AC-coupled might be the issue.
But is there any suggestion how to make this work?Location: The Netherlands
