Home › Forums › Product Discussion & Questions › BeoLab › Beolab 8000 with no power
- This topic has 6 replies, 4 voices, and was last updated 3 years, 3 months ago by
KolfMAKER.
2 January 2023 at 10:29 #42047
beoladdy
BRONZE MemberI’ve had a couple of Beolab 8000s for a while now and both have worked well except for humming when connected to RCA. After being stored for a year now only one of them is working. Found that the nut on both RCA connectors was loose which I tightened and now the humming is gone from the working speaker. There was foam rot, but it seems the PCB’s are in good condition.
– There’s no click from the relay
– No red or green LED
– There’s no voltage across the pin 7 + 9 or pin 10 + 12 on T2 which should be at 20V.Although it visually looks fine I’m thinking T2 might need a replacement, but maybe there’s something I’m not considering… ?
If T2 needs to be replaced, where can I get one? (shipping to Norway)
Is there also a place where I can get replacement foam? I’m also changing the foam on the working speaker.2 January 2023 at 23:21 #42048 Luke466BRONZE MemberFrom Beowrold notebook-
https://beocentral.com/notebook/beolab-8000
Beolab 8000
24th October 2008It is not unusual to find these loudspeakers to be completely dead with not even the red standby indicator showing. The cause is usually the standby transformer, the primary winding burns out. B&O now supply only the complete amplifier as a replacement part, this is a very expensive way to deal with such a simple fault. An alternative is to source your own transformer, RS Components 504-363 being one alternative. The pin arrangement is slightly different so some cutting and bridging of the trackwork of the PCB will be necessary. [Beolab 8000]”
3 January 2023 at 12:50 #42049 KolfMAKER
BRONZE Member@ beoladdy
Very interesting. I have a BeoLab 8000 that started having problems with switching ON>OFF>ON continuously. See this thread.
After measuring all over the PSU PCB I found inconsistent voltage on T2: 20 volt on pin 7 & 9, and 23 volt on pin 10 & 12.
Just a few days later, the BeoLab was completely dead, like you describe. Measuring T2 again shows: 230 volt on pin 1 & 6, and 0 volt on pin 7 & 9 and pin 10 & 12. So the same situation as yours.
@ Luke466
Thanks very much for sharing your experience with the RS Pro replacement trafo!
So thank you both, I consider my problem with the dead BeoLab 8000 solved.
Though I will post again when I have replaced T2.Location: The Netherlands
3 January 2023 at 13:16 #42050beoladdy
BRONZE MemberThanks @ Luke466
@ KolfMAKER
I ordered this replacement power supply: https://kosetrading.com/product/bang-olufsen-bo-beolab-8000-mk1-transformer-part-pcb-1-8006038/
It might work for now, but let me know if the RS trafo works for you. I might need to replace it at a later time.
Just wondering if the 15V is enough to power the system. Hope it works
3 January 2023 at 14:23 #42051 KolfMAKER
Yeah, I have seen the Kosetrading part. Unfortunately it’s the whole PSU-PCB, not only T2. And also it’s a lot of money to solve a dead T2 trafo.
Sure, I will let you know about the RS Pro trafo.
3 January 2023 at 16:24 #42052 BeobuddyGOLD MemberI can provide the correct transformer for 230V market. Fit’s in the original position.
PM me for details.Ebay and other versions with 15V are incorrect.
Beobuddy.
3 January 2023 at 17:22 #42053 KolfMAKER
BRONZE MemberThanks for reminding Beobuddy.
I have just sent a PM for ordering a T2.Location: The Netherlands
