Home › Forums › Product Discussion & Questions › BeoLab › Beolab 8000 rubber feet
- This topic has 7 replies, 4 voices, and was last updated 3 years, 6 months ago by
styppen.
6 September 2022 at 08:55 #38887
styppen
BRONZE MemberHi all
Any ideas where I could get rubber feet for the base for Beolab 8000?
My 8000s came without rubber feet I would really like to add them since the speakers are standing on a hardwood floor.
Thanks!
7 September 2022 at 06:42 #38888Valve1
GOLD MemberI am sure the felt pads you buy for furniture in a DIY place will suffice.
Did 8000’s not come with adjustable feet ?
7 September 2022 at 07:07 #38889 KolfMAKERBRONZE MemberFelt is an option.
Though I use rubber feet by Delock 10 x 3 mm. These fit in size.
https://www.delock.com/produkt/18309/kaufen.html
7 September 2022 at 07:08 #38890 TignumGOLD MemberHello styppen, they are called
and are indeed adjustable (I took one from my 8000):
But if you cannot find the real ones, maybe you can find some short, flathead M5 bolts (called thumbscrews) and stick a rubber protector on it (one like this:)
Then you will still have the possibility to adjust the stance.
Good luck! Johan
7 September 2022 at 08:04 #38891 KolfMAKERBRONZE MemberJust to be sure, are you looking only for the rubber feet, or also the metal bolts?
7 September 2022 at 08:16 #38892styppen
BRONZE MemberI’m looking for metal bolts with rubber feet. The same as Tignum posted in his first photo.
I would really like to get the original replacement parts. If I’m not able to find any, I’ll conjure something up with generic bolts and rubber pads 🙂
7 September 2022 at 08:42 #38893 TignumGOLD MemberHi again, here they can be bought: https://www.idav.nl/rubberen-voetjes-beolab-8000.html?id=268961159. Not cheap – 50 euros for 8.
8 September 2022 at 14:28 #38894styppen
BRONZE MemberThanks Tignum. Exactly what I’m looking for!
