Home › Forums › Product Discussion & Questions › BeoLab › BeoLab 8000: problem with crackling noise
- This topic has 3 replies, 2 voices, and was last updated 2 years, 6 months ago by
KolfMAKER.
15 August 2023 at 11:45 #48262
KolfMAKERBRONZE MemberSituation / problem
I have a BeoLab 8000 (ser. 1171 xxxx) that sometimes produces a crackling noise. At that moment the music is pushed away, and sometimes the noise goes and the speaker is just silent for a short moment (a second or so). After that, it just plays music again.
The other speaker in this pair of 8000’s does not have this issue.
Both speakers have functioned without any problem until recently.Question
I hope someone recognizes this ‘behavior’.
(a) What could be wrong?
(b) Where should I check?Location: The Netherlands
15 August 2023 at 12:07 #48263Die_Bogener
BRONZE MemberSounds like a crack of a copperline of the board (foam rot?) or defect cap in the power supply or soundpath.
15 August 2023 at 12:53 #48264 KolfMAKERBRONZE MemberDanke @Die_Bogener!
Concerning foamrot, it’s no foam. I made a typo with the serial. This 8000 has serial 1711 xxxx. So a MKII, built with the new white foam.
I will check for copperline cracks and defect caps.
Any other ideas are welcome.
31 August 2023 at 12:33 #48265 KolfMAKERBRONZE MemberBy making a check on the PCB with a loupe, I found two cracks.
After re-establishing the connection, the speaker works fine again.Thnx!
