Home Forums Product Discussion & Questions BeoLab Beolab 8000 – passive build
  • This topic has 0 replies, 1 voice, and was last updated 1 year ago by Ti Lo.
Viewing 1 post (of 1 total)
  • #64312
    Ti Lo
    I have two Beolab 8000 MK1 (cleaned, white foam), because I really like the design. They are connected to a small streaming box (Arylic S10+) where I can switch inputs from TV to Bluetooth to Wifi.
    The speakers behave as they should, but not as I would like them to. I hear white noise and ticks, when I am really close. Problably also from the streamer and the grounding. Additionally the speakers turn off in quiet movie scenes. Additionally I am always afraid that they blast full volume, since the volume control is not an analogue knob.
    My question:
    Does it make sense to turn the speakers to passive speakers?
    Pros:
    • less wires
    • less noise, since the analogue signal from source to amp is shorter
    • no brittle PCB anymore
    • no turning automatic on and off (I like to do that manually with a power switch)
    Cons:
    • can I achieve around the same sound quality?
    • need a passive crossover –> which one?
    • not original anymore
    That post gave me the idea: Reddit Link
    I just want to hear your ideas and concerns.
