Home › Forums › Product Discussion & Questions › BeoLab › Beolab 8000 orange status light
- This topic has 3 replies, 3 voices, and was last updated 1 year, 1 month ago by
BeoIce.
8 January 2025 at 21:46 #62431
BeoIce
BRONZE MemberHey,
got a pair of BL8000 MK1, one speaker is ok, but the other shows orange status light and there’s no sound output at all.
What can be the cause and what to look at exactly ?
9 January 2025 at 15:43 #62442 filip_kbh
BRONZE MemberCheck the foam in the speaker. If it is gray, it will have started to become a sticky mess that eats away traces at the amplifier section. This is a well-known problem – search in the old forum and you will find lots of info about it.
6 February 2025 at 16:26 #63470LeHe
BRONZE MemberOpen it and see if the PCB’s has been affected by the black damping material. If so clean and repair the PCB’s.
If repairing ready or if no black damping material ( the series from about 2000 had new white damping foam ) then you will have to do some measurements with a multimeter. If you have one and still have a little knowledge of the subject, I can guide you further in de repair process, if not look for a local electronic hobby man or go to the Dealer.
No sound actually means a power problem +/- 50 volt for the power amplifier. Do you hear the internal relais switching on any moment.
6 February 2025 at 19:11 #63477BeoIce
BRONZE MemberThank you both for your replies.
I will check the internal relais.
As I aquired a newer pair of beolab 8000 I will disassemble the old pair to try what is possible to repair them.
I will get back to you Leon for guiding me through the repair process if possible. If I get the one beolab back to live I would like to recap them. But this depends also on the in the units.
