Home Forums Product Discussion & Questions BeoLab BeoLab 8000: On Line/RCA input, always red LED ?
Viewing 5 posts - 21 through 25 (of 25 total)
  • #61343
    Keith Saunders
    FOUNDER Member
      Given you only have a basic multi-meter you could try the following, it is a long shot, but worth a try.
      With a signal (music would be best) plugged into the phono socket use you multi-meter set to AC volts say 1 volt range if it has one, or the lowest available. What we are trying to do here is measure an analogue signal with a AC volt meter and compare the good speaker with the bad.
      One meter lead on P2 pin 2 and the other lead on each of the following points on both speakers with the same music input.
      • Both sides of C75
      • IC1 pin1
      • Both sides of R136
      • Collector of Tr16
      Note any points between the two speaker with a difference.
      #61345
      Glitch
        One could also use MP3 sine wave test tones which might make it easier to do comparisons.
        Glitch
        #61354
        Keith Saunders
        FOUNDER Member
          One could also use MP3 sine wave test tones which might make it easier to do comparisons. Glitch
          Yes I agree..
          #61358
          KolfMAKER
          SILVER Member
            Thanks again gentleman!
            I will start to measure between the ‘bad’ and a good speaker next week. As you suggested Keith, between P2 pin 2 and the listed components.
            I have a sin wave app on my phone which I will use as a continuous audio signal.
            To be continued!
            #61526
            KolfMAKER
            SILVER Member
              Today I tried starting the comparison measurements. As a reference / working speaker I wanted to use another BeoLab 8000 with serial 16xx xxxx. But I found out that the PCB layout of components is slightly different than the trouble BeoLab I am working on (13xx xxxx), and from the PCB02 drawing I have from the Service manual.
              To show the difference: first the drawing of PCB02 I have from the Service Manual, and underneath a picture of PCB02 from the 16xx xxxx speaker I wanted to use for comparison.
              BeoLab 8000 - PCB02
              PCB02 - Layout 16xx series
              IC1 is still clear, but I am not sure about the position of C75, R136, and TR16.
              Question
              • Could you help me find where these components are, or maybe you have a visual layout of this PCB02 version?
