Home Forums Product Discussion & Questions BeoLab BeoLab 8000 modification: do you know this?
Viewing 6 posts - 1 through 6 (of 6 total)
  • #49007
    KolfMAKER
    SILVER Member
      I recently saw a BeoLab 8000 with a capacitor added to PCB02. It looked like in the pictures below. I believe the capacitor is connected to two pins of the main IC.
      Question
      Does anyone know what kind of modification this is, or what it solves?
      IMG_0142-b
      IMG_0143
      Close-up
      #49008
      Die_Bogener
        Is the crossover network still existing and fully mounted?
        Otherwise ist could be a bypass for the crossover…
        But it looks like a standard work of B&O… ???
        Check, wether this cap manufacturer is also used on the board.
        #49009
        KolfMAKER
        SILVER Member
          Thnx for responding Die_Bogener!
          Answering your questions …
          • Yes, the crossover network is existing and fully mounted.
          • I am not sure if this is the standard work of B&O. I showed a picture to a former B&O repair engineer. He did not recognize this.
          • The cap manufacturer I believe is different than what’s used on the PCB’s.
          #49010
          Die_Bogener
            Probably the crossover ist defect or the one who did this wanted to change the sound.
            Either more bass or treble… but without filter this is senseless and will destroy the speakers.
            If it is treble: very nice to send low frequencies to a tweeter, this will extend lifetime… to some minutes.
            And if it is bass: ok, this will kill the amp…
            #49011
            KolfMAKER
            SILVER Member
              Thanks again for your comments!
              I have removed the capacitor, to check if this made a difference.
              Result = no difference. Sound is the same, functioning of the speaker system is the same.
              I will just leave it as is, without the capacitor. Probably better to avoid damage.
              #63846
              LeHe
              SILVER Member
                Came across this old post.
                This modification was also applied ex works to my 1995 1155 xxxx speakers. ( same construction)
                Checking the PCB02 schematic shows that this capacitor 4.7 uF has been applied as an additional interference suppression and smoothing on the negative supply of – 15 volts.
                I think that de reason for this modification was discovered during the final test of the product. Maybe interference or voltage dips.
                So leave it as it was  or rebuild it. The manufacturer did this for a reason and is not a hobbyist’s invention.
                • This reply was modified 3 weeks, 1 day ago by LeHe.
