Home › Forums › Product Discussion & Questions › BeoLab › Beolab 8000 Damping Material
- This topic has 2 replies, 2 voices, and was last updated 1 year, 11 months ago by
kktsui.
29 March 2024 at 02:53 #53905
kktsui
BRONZE MemberHello B&O fans,
I notice most of the Beolab 8000 MK 1 version has the problem of rotting damping material inside. I have a pair of Beolab 8000 MK2 with serial 20959413, anybody knows if this MK2 has the same problem? I understand that the problem will eventually cause harm to amplifier and power supply board, therefore I want to know if I need to replace the damping material. Thanks in advance.
Best Regards, Peter
29 March 2024 at 15:11 #53906 KolfMAKER
BRONZE MemberHi Peter, no issues with the type of foam in your speakers.
BeoLab 8000 MK I has the improved type of foam, much better resistant to temperatures caused by the internal amplifier and PSU.
So, no problem.
29 March 2024 at 15:20 #53907kktsui
BRONZE MemberHello KolfMAKER, That’s great, my speakers are no need to change the foam. Thank you so much for your comment!
