Home › Forums › Product Discussion & Questions › BeoLab › BeoLab 8000 – Converting 110V US Version to 220V EU (Transformer Question).
- This topic has 0 replies, 1 voice, and was last updated 3 weeks, 4 days ago by
Sergey Matkovsky.
Viewing 1 post (of 1 total)
10 March 2026 at 09:17 #76431
Sergey Matkovsky
BRONZE MemberHi guys,
I want to modify my 110V US BeoLab 8000 speakers to work with 220V EU voltage.
From the manual, I see that there are several versions of the power input PCB, and the difference between them seems to be the connection to the transformer (T1). From what I can tell, this connection appears to be the only difference.
It looks like I can modify the wiring from the 110V configuration to the 220V configuration.
My question is whether the transformer (T1) is identical in both versions, or if I would need to replace it with a 220V version as well.
