Home › Forums › Product Discussion & Questions › BeoLab › Beolab 8000 – constantly turning on and off
- This topic has 4 replies, 3 voices, and was last updated 1 year, 2 months ago by
Henry Warkehr.
17 January 2025 at 20:52 #62846
Henry Warkehr
BRONZE MemberHello,
I saw there has been a similar question a while ago but unfortunately no answer. So I hope some of you experienced something similar and have been able to find a solution.
Both of my Beolab 8000 speakers have been displaying a weird behavior for a while now. They are connected to a streamer (node 2i) over the optical outlet. This set-up has worked quite well until a few weeks ago, since that point, once I pause whatever is playing on the TV they neither stay on nor off but always change between modes (see attached video). They are no pattern in them turning on/off, sometimes they change after a few seconds and sometimes after a couple of minutes.
Did anyone have similar experiences and know how to repair it?
Many thanks in advance!
Henry
18 January 2025 at 09:30 #62851 Capt’nGerard, formerly known as GaeaGOLD MemberHas the black foam been replaced?
20 January 2025 at 07:37 #62906Henry Warkehr
BRONZE MemberHey Gaea, thanks for your answer. As far as I know, the foam hasn’t been replaced yet. However, I wonder how the foam could have this effect. Isn’t the foam just the insulation?
20 January 2025 at 10:00 #62912francoisvl
BRONZE MemberThe Foam starts to disintegrate and becomes a sticky goo that damages the PC boards causing a lot of issue and ultimately causing the speaker to stop working. Corrodes everything.
20 January 2025 at 10:46 #62916Henry Warkehr
BRONZE MemberThen I will check for the insulation material first and see if that will fix the problem. Thank you so much.
