Home › Forums › Product Discussion & Questions › BeoLab › BeoLab 8000: auto standby OFF > ON > OFF > ON repeatedly at RCA/Line IN
- This topic has 0 replies, 1 voice, and was last updated 1 year, 8 months ago by
KolfMAKER.
18 December 2024 at 19:59 #61721
KolfMAKER
BRONZE MemberI have one BeoLab 8000 (serial 16xx) that has a strange problem.
What happens & problem description
I use an audio source connected to the RCA/Line IN input. When starting music it switches from stand-by to On, just as it should.
When I end the music, it in most cases also goes back to stand-by/Off.
But …
After a while (which means starting and ending music several times) it switches like this:- It goes OFF > ON > OFF > ON > OFF and then stays OFF. Or …
- It switches OFF > ON > OFF > OFF etc. repeatedly.
Speakers noise/hum/buzzFrom the speaker drivers I hear no noise, hum, buzz or any disturbance. They are quiet, only slight noise when one puts his ear in 5cm range of the driver.
Testing & auto stand-by behavior (in RCA)I noticed that the time when the auto stand-by switch becomes active, changes when repeating start & stop playing music. So first it goes back into stand-by after 2m:45s, but this time becomes longer after starting and stopping music several times after each other. At some point it takes over 4 minutes, which to my experience is quite long.
The error switching (OFF > ON > OFF > ON, …) sometimes happens after 2m:20, and sometimes after 4m:15s.
Switch from RCA to PLWhen the RCA input is active and the auto stand-by switches OFF > ON repeatedly, and when I then push the RCA switch into the PowerLink position, I hear a BUZZ coming up to some point, and then the speaker switches to stand-by/Off (and stays OFF).
- What does this mean?
PowerLink & Auto stand-by testedTested with a BeoSound as source, connected via PowerLink. When music is stopped and the BeoSound is being switched off, auto stand-by immediately goes to OFF.
PL/RCA switch- When pushing the PL/RCA selector switch to a different position, electric noise can be heard.
- After cleaning this switch with Tuner600 (4 times), the electric noise when switching is much less.
What I checked/did
- I did find some dirt and solder particles on PCB05 and PCB02. I cleaned those.
- On PCB02, PCB05 and PCB06 I re-soldered several pins/components and connectors.
- After this, with the speaker lying open on the work bench, I got it into a working state. So, auto stand-by had no issues.
- Next, I placed the AMP/PSU part back into the speaker casing, and I did the same with the speaker panel. Though I had the speaker panel standing open. Also in this case, auto stand-by had no issues.
- Then I put the speaker panel inside the speaker casing, and the auto stand-by started going OFF > ON >OFF> ON repeatedly again. It continued like this also after fixing all screws in the speaker and in the AMP/PSU panel.
After cleaning, checking for dry solder joints and re-soldering again, I found the speaker to be more stable. I repeated this test 14 times:
- From stand-by mode, start playing music, via RCA input, and stop the music.
- This worked well 13 times.
- In all 13 cases the speaker switched ON at starting music, and switched back to stand-by after stopping music.
- The wait time until switch back to stand-by was varying, between 2m:15s and 4m:17s.
- After the 14 time, the speaker started to repeatedly switch again: OFF > ON > OFF > ON > …
Question- Since this speaker works partially ok, but sometimes not, could there be anything wrong with grounding?
- What should I check or fix?
