Home › Forums › Product Discussion & Questions › BeoLab › Beolab 8000 + Active + Sonos Connect
- This topic has 3 replies, 2 voices, and was last updated 3 years, 2 months ago by
Millemis.
4 February 2023 at 07:52 #43519
Prime
BRONZE MemberHi,
I’m looking for a way to turn on my Beolab 8000 over Powerlink when my Sonos Connect starts playing. I don’t have a 5v trigger.
what if I use a Beolink Active and connect it with my Sonos on the aux and I connect my Beolab 8000 to the Active with Powerlink.
would this setup work? And is the IR eye needed for the Active in this setup?
4 February 2023 at 10:28 #43520 Millemis
BRONZE MemberYou do not need any additional gear for that.
Have a look at Steve’s video here:
(If you are in a hurry start at 2:19)MM
4 February 2023 at 13:19 #43521Prime
BRONZE MemberSadly my autostart doesn’t work anymore on the line in 🙁
4 February 2023 at 15:02 #43522 Millemis
BRONZE MemberBever heard of that before.
Anyway – you can not use a Beolink Active as a standalone device.
In that case, only option you have is a B&O Audiomaster/Beocenter/Beosound for the PL and for connecting to a free port (A.Aux/A.Tape……) there.MM
