Home › Forums › Product Discussion & Questions › BeoLab › Beolab 8000 ABL
- This topic has 6 replies, 3 voices, and was last updated 3 years ago by
matador.
20 March 2023 at 09:58 #44842
kronzilla
BRONZE MemberHello, i’m searching for the service manual for the lab8000 abl but dont find it. And the original one is useless.
Help is appreciated.
( Ps: you can download everywhere on the net the nirnal one)
20 March 2023 at 22:11 #44843 KolfMAKERBRONZE MemberWhat is your serial number?
21 March 2023 at 00:54 #44844kronzilla
BRONZE Member20xxx and i know they are mk2 with abl (aka mk3).
Actually i know exactly that there are 4 versions of the 8000…
And i hear the difference between mk2 and mk2 ABL too…
21 March 2023 at 09:19 #44845 KolfMAKERBRONZE MemberI know there are different types of the BeoLab 8000. Most people talk about MK I and MK II. The MK II often described as having the ‘bass update’. BeoLab 8000 MK II has serial number 16992475 and up.
I have also been told that the BeoLab 8000 had an ‘ABL’ function form the first model onwards. But that it was changed with later versions.
I recognise three models: MK I, MK II and 8002. But I am also intresten to learn if there’s even a 4th model, and what others believe the differences are. So anyone, be invited to add your knowledge!
Concerning the Service Manual: as far as I know, there is only one Service Manual.
21 March 2023 at 14:51 #44846 matadorModeratorI think that early models have a “cup” woofer and later a “dome” woofer. I believe the “dome” woofer is more bassy. Where is the split? I don’t know.
21 March 2023 at 15:11 #44847kronzilla
BRONZE MemberIt is not that easy. It is not only the woofers but partially the amplifiers too.
21 March 2023 at 17:18 #44848 matadorModeratorI know. Just saying that “at glance” it’s an obvious difference, as much as the leds from the 8002 are.
