Home › Forums › Product Discussion & Questions › BeoLab › Beolab 8 arrived…
- This topic has 42 replies, 14 voices, and was last updated 2 years ago by
Millemis.
10 March 2024 at 16:36 #50600
MillemisBRONZE Memberbut now I have a question :
I’ve been through eclipse settings , and beolab settings on app , and can find no setting for using the 19 sub with the 8s for music streaming .
is it possible to do this ?
or will the sub only turn on when the tv is on , and the 8s will only stream Bluetooth when tv is off ?
You can not add a sub to the BL8’s.
Only way is to make a Speaker Group with the BL8’s and the BL19 in the BV Eclipse – which means that the BV Eclipse will turn on for processing the sound.
You can not use the BL8’s for BT, when set up with the BL19 as a Speaker Group.As far as I remember you can stream via BT to the BV Eclipse directly and this way use the BL8/19 Speaker Group for listening.
10 March 2024 at 18:39 #50601Ianc2
BRONZE MemberThanks for confirming .
to be honest , the fact they can stream Bluetooth quick and easily when everything is turned off is a MAJOR plus that I will rarely use , but I suspect it will be used often by others .
the sounds they produce is more than acceptable as is .
10 March 2024 at 20:15 #50602 MillemisBRONZE MemberIMO streaming via BT is a handy solution, when you e.g. have guests in the house and you are not interested in giving them the password for your home wifi network.
Streaming via Airplay or Chromecast / Deezer, Spotify Connect (or Tidal Connect) is the better solution.
