Home › Forums › Product Discussion & Questions › BeoLab › Beolab 7.4 hiss with BeoPort and Beolink Active
- This topic has 10 replies, 4 voices, and was last updated 3 years, 4 months ago by
Blokkenpiloot.
12 June 2023 at 12:53 #47146
Blokkenpiloot
BRONZE MemberHi all,
I used an Beosystem3 for driving a Beolab 7.4 speaker, which worked great!
But when i connected it to an Beolink Active, there was an high pitched hiss, and an rumble.
Even without volume or without connecting an audio source.it’s not the hiss you get from loud volume, because when i increase the volume, the constant hiss stays the same until an point about 2/3 high, and then increases with the volume. It has the same sound though, but will remain even at lower volumes.
I made an custom cable connecting pin 2 and 7, and on the Beoport, there isn’t any rumble anymore with the 7.4 speaker. Great!
But the 7.4 still has the higher pitched hiss compared to the Beosystem 3, with all cables the same!
I couldn’t get this trick to work on the beolink active though.
How can i better tackle this issue? is there another device that i can use instead of the beolink active or beoport? Ofcourse i can use the Beosystem 3, but that’s a bit overkill for only one 7.4 speaker.
Thanks!
13 June 2023 at 13:59 #47147Madskp
GOLD MemberHello
At least in some products pin 2 and 7 are internally connected in the device or pin 7 is not connected at all.
An idea could be to disconnect pin 7 in the cable to see if the hiss disappear. My suspension is a ground loop.
13 June 2023 at 14:46 #47148Blokkenpiloot
BRONZE MemberHi There, Thanks for your suggestion.
I just desoldered pin 7, which i connected to pin 2. And the deeper hum was back.
When i touched the (loose) wire 7, to pin 2, the hum was gone again, and only the high pitched “static” was back.On the BeoPort/PC2, the static volume is about 60, because when i increase the pc2 volume to over 60, the static noise will get louder, but under 60, stays at the same volume.
I also noticed when my ear is almost inside the tweeter, there is an small “Ticking” sound every second.
4 audio files are added, all recorded from the same distance and without audio inputs on the PC2, i even removed the USB connection but no difference. So only power and the powerlink are connected.
The hum on the beosystem 3 is the same sound, but way lower in volume, and without the tick every second.
(can’t add audio files, so hosted them myself, right click and save as, to prevent addblocker)
https://www.aymeric.nl/hum_with_2_and_7_volume_0.m4a
https://www.aymeric.nl/hum_with_2_and_7_volume_72.m4a
https://www.aymeric.nl/hum_without_2_and_7_connected.m4a
https://www.aymeric.nl/hum_same_cable_beosystem_3.m4a14 June 2023 at 14:02 #47149Madskp
GOLD MemberI just desoldered pin 7, which i connected to pin 2. And the deeper hum was back. When i touched the (loose) wire 7, to pin 2, the hum was gone again, and only the high pitched “static” was back.
I am a little unsure what you actually did when you write that you desoldered pin 7 and connected it to pin 2, but you also have a loose wire?
Just to clarify my idea was to remove the connection to pin 7 in both ends of the cable and not use that wire at all as the wire on pin 2 also is a ground connection.
Not sure if it will work as the official B&O powerlink cables does have both ground connections.
Also maybe check your pinout with those in the Beolink Handbook from page 102 https://beoworld.org/beolink-handbook-version-1-9/
Note that there are several versions.
14 June 2023 at 14:25 #47150Blokkenpiloot
BRONZE MemberThanks, i’ll look into that handbook.
To clarify:
1. I took the powerlink connector on one side of the cable. And desoldered the wire to pin 7, which then hangs loose. So pin 7 didn’t make any contact with the Beolink PC2.2. there was an deep rumble coming from the speaker
3. i then soldered a small wire to pin 2, next/on to the original ground attached to pin 2.
4. i then touched the other end of that wire to the wire i just soldered off of pin 7. So on the Beolink PC2 side, pin 7 was still disconnected, and on the speaker side, pin 2 and 7 were connected.
5. The deep rumble was gone, but the high volume hiss stays. It’s the same as keeping all 8 pins connected on the cable, and connecting a small wire between pin 2 and 7.
6. When using the same self soldered wire on the Beosystem3, the high hiss is present, but at a way lower volume compared to the Beolink PC2, both with volume on 1 (on zero will be quieter) AND on the Beosystem3 there is no ticking noise once a second, but that’s not audible from a normal distance, this hiss is.
14 June 2023 at 14:32 #47151Blokkenpiloot
BRONZE MemberAt the handbook they refere to pin 7 with the “braided shield”, on my cable it’s the other way around. Pin 2 has the shield and 7 the other ground.
I can try to change it around, but since it’s working with this cable on my Beosytem 3, i don’t think it’ll work. But it’s easy to try!
14 June 2023 at 15:16 #47152Madskp
GOLD MemberAt the handbook they refere to pin 7 with the “braided shield”, on my cable it’s the other way around. Pin 2 has the shield and 7 the other ground. I can try to change it around, but since it’s working with this cable on my Beosytem 3, i don’t think it’ll work. But it’s easy to try!
that might have something to say.
With original powerlink cables this behaviour can also differ from product to product depending on the type of powerlink cable used
18 June 2023 at 22:54 #47153 filip_kbhBRONZE MemberIn the manual for the 7-4 it says to use a specific type of Powerlink cable as others can cause hum.
19 June 2023 at 07:57 #47154Blokkenpiloot
BRONZE MemberYes i know, MK3. But it’ll hum with all cables, (Old full wired powerlink, MK2 and MK3) on the Beolink PC2, and with the same cables on the BeoSystem3, its good.
19 June 2023 at 11:25 #47155RaMaBo
GOLD MemberHi,
the Beolink active (1636) has a different connetion option than the older Beolink active (1616).
The older has two powerlink connections which should work flawlessly with a MK3 powerlink cable.
The newer Beolink active (1636) has one connection as PC (to the computer) and _one_ powerlink connector.May be the BeoLab 7.4 is connected to the wrong socket? It should be connected to the powerlink socket.
19 June 2023 at 12:15 #47156Blokkenpiloot
BRONZE MemberI have the active with PC and Powerlink. It’s attached good, because there is sound (playing from the PC port into the Powerlink socket, but even without the PC port connected, the “hiss” stays)! So yes it works, but there is an way louder “hiss” sound coming from the 7-4 when connected to the Active, Beoport, compared to the BeoSystem 3
But yes maybe i’ll try that older one if i come across one, didn’t know about the difference, thanks!
