Home › Forums › Product Discussion & Questions › BeoLab › Beolab 7.2 repurpose
- This topic has 4 replies, 3 voices, and was last updated 3 years, 9 months ago by
patcherley.
13 June 2022 at 08:11 #35470
patcherley
GOLD MemberI am thinking of using my now redundant Beolab 7.2 with a BeoSound Core. Would it be possible to power the Core from the Beolab 7.2? Thanks in advance. Paul
Favourite Product: Beolink 7000
13 June 2022 at 20:37 #35471 Steve at Sounds HeavenlyGOLD MemberHi Paul,
Yes, it is easy to connect the Beolab 7-2 to a Core, you just need this cable:-
Please note that both the speaker and the Core each need their own mains power connection.
Kind regards, Steve.
13 June 2022 at 21:38 #35472patcherley
GOLD MemberSteve,
Thanks for this, I will contact you when I go ahead.
Have I misread the beolab 7.2 manual when is says “Mains connections The loudspeaker has two sockets concerning mains supply. The socket marked ~ is for mains supply input (connection from the wall outlet), and the other is a mains supply output to BeoVision 7 “, I thought I might be to power the core from here.
21 June 2022 at 17:24 #35473RaMaBo
GOLD MemberHi,
the Core could be connected to the Beolab 7.2 with a power cable with the matching connectors ( two C7 plugs ). It’s the same way the Beovison 7 is connected to power, except you use a Core instead of the TV 😉
21 June 2022 at 18:17 #35474patcherley
GOLD MemberThanks for that, it was I thought but wanted to check. I thought the core had a USB-c power connection.
