Home › Forums › Product Discussion & Questions › BeoLab › Beolab 7-1 used as centerspeaker with non-B&O TV.
- This topic has 4 replies, 2 voices, and was last updated 3 months, 1 week ago by
boj.
21 December 2025 at 07:03 #72043
boj
BRONZE MemberDear Forum.
I am using a beolab 7 centerspeaker on my non-B&O TV. The speaker is connected to the TV with a special cable with powerlink, mini Jack and usb-trigger. The cable is connected to a digtital to analog hdmi-arc converter. Now to my question:
The setup is always powered on. My beolab 7 is always a bit warm – also when not in use. Is this normal or could there be a overheating problem?
I also need to say that the setup works fine with no other complications.
thanks in advance.
Bo.
21 December 2025 at 11:48 #72045DT79
BRONZE MemberI have a similar set-up with a 7-2. I’ve got a cable which takes a power trigger from the TV’s USB and audio from my AVR via an RCA female socket, all into the Powerlink plug. My 7-2 is only on when the TV is on. It sounds like your TV gives a constant power from the USB socket, hence the 7-1 is always on. Check out the instructions for your TV, if there’s more than one USB socket then one of them might not be ‘always on’, or it might be something you can adjust in the settings.
As to whether it’s doing any harm, probably not if you aren’t worried about the power consumption (which should be minimal). ‘A bit warm’ is fine, possibly even preferable to longevity than repeatedly warming up and cooling down.
21 December 2025 at 13:08 #72046boj
BRONZE MemberI am powering the usb trigger from a normal powersocket. Could that be the mistake instead of powering it from the TV?
21 December 2025 at 13:27 #72047DT79
BRONZE Member100% yes. Plug it into a USB on the back of the TV and it will almost certainly power up/down with the TV.
22 December 2025 at 17:24 #72060boj
BRONZE MemberHi DT79.
Thanks for Your insigths. It helped.
Regards, Bo
