Home › Forums › General Discussion & Questions › General Discussion & Questions › Beolab 6000/6002 in 2025
- This topic has 3 replies, 4 voices, and was last updated 12 months ago by
B&O Orlando.
23 February 2025 at 20:05 #63973
20cen
BRONZE MemberHi all,
I am thinking of a buying a second hand B&O HIFI system, and I was curious to get your input for a system that includes 2 beolab 6000/6002 (most likely 6002)
What do you think about these speakers compared to the actual B&O speakers (balance, A9…), and how you would connect them?
I have to say that I am not a big fan of high volume and bass (so the 28hz low frequency of the BS balance is not an argument for me 🙂 )
Thanks a lot!
23 February 2025 at 20:48 #63975 Severed_hand_of_skywalkerBRONZE MemberIf you don’t care about Bass and they are cheap enough go for it. They would use older Powerlink Cables which should come with the system or speakers.
24 February 2025 at 17:08 #63989 matadorModeratorI Agree, 6000 are classics and I’m close to rather like 6000 over 8000’s.
Beware with 6002 that are know to sound more crisp (cold/metallic?) than 6000 and in all case be sur to check the speaker surronds that are prone to disintegration.
24 February 2025 at 17:14 #63990 B&O OrlandoBRONZE MemberBeolab 6000s are still very impressive speakers. Their biggest downside is the lack of low end as they only use two small 3.5″ woofers. They sound great in a small room but could also work in a larger room for background music. A sub could be easily added, and then you’d have a really great sounding system. Beolab 2 and Beolab 11 subwoofers will work natively. You can have a really nice and easy to use system with a Beconnect Core and a pair of BL6000s.
