Home › Forums › General Discussion & Questions › General Discussion & Questions › Beolab 50 rattling front covers
- This topic has 5 replies, 3 voices, and was last updated 1 year, 5 months ago by
Dstefan.
24 August 2024 at 19:39 #58608
Dstefan
BRONZE MemberFor two weeks now I have a set of 50’s as a replacement for my beloved 5’s. However, I experience a strange phenomenon. The front covers make annoying vibrating sounds with certain bass at high volume. The woofer gives so much air displacement, that in my opinion it cannot get out. Seems like a construction error. Does anyone have experience with this by chance (and a solution). Of course I also informed my dealer, but I have not heard anything from them yet. B&o support also refers to the dealer.
25 August 2024 at 20:04 #58623 yossi
BRONZE MemberI had the same problem until my dealer changed the woofers… now everything is quiet and precise
26 August 2024 at 13:23 #58627 YannChris
GOLD MemberHi,
I would like to test my own 50s.
May you tell me some titles on which you observed the problem?
Kind regards,
Yann.
10 September 2024 at 16:46 #58984Dstefan
BRONZE MemberHi,
Well, my dealer replaced the front covers and that solved the problem…altought at some very high volume levels, I can still hear some vibration. Try Way down deep from Jennifer Warnes or See mi yah from Rhythm & Sound.
11 September 2024 at 16:51 #59010 YannChris
GOLD MemberThanks fot the tiles.
I’ll check them.
What kind of covers do you have? Fabric, wood or aluminium?
Kind regards,
Yann.
11 September 2024 at 16:57 #59011Dstefan
BRONZE MemberHi,
I have the fabric ones. Love the aluminium ones, but quite expensive..
Regards, Stefan.
