Home › Forums › Product Discussion & Questions › BeoLab › Beolab 50 First set up
- This topic has 2 replies, 3 voices, and was last updated 1 month, 2 weeks ago by
B&O Orlando.
8 May 2023 at 02:41 #46502
Drisolution13
BRONZE MemberHello Community !
I recently purchased a pair of Beolab 50, with the beosound core included.
I am normally a technical person but as new to Bo world, I need some support.
The speakers are bought second hand and of course didn’t think it would be a problem to make them play and configure …. but 🙂 let me explain :
Master and slave connected to DPL port on each by 5m Cat7 cable.
Little Cat 7 cable connected on the Master (powerlink port) and the beosound core (powelink port).
Iam able to see the core on my BeO App and play music on it and hear it on the speakers. but I have no option to add the beolab 50 to the app neither has any options concerning wide or anything on the core. basically I am missing a step that I can find online.
On my app I literally have only the core and cant add the beolab as they are not founded. Did I miss something somewhere ?
I could ask BeO to come home to fixe it of course, but it might be a simple trick ?
Hope somebody can help, I look forward to hear them play
13 January 2026 at 12:36 #72525robert.buczynski
MemberHi. I’ve just got a pair of bl50 this weekend and have the same problem. I have the speakers connected to the Beoconnect Core but can’t add the to the app or BS Theatre via WPL. Would you be able to share how you have done this? Thanks.
Rob14 January 2026 at 21:49 #72550 B&O Orlando
BRONZE MemberYour best course of action will be to factory reset the Core and 50s. To reset the Beosound Core, hold the configuration button (gear) for 10 seconds. The light will flash red briefly. To reset the 50s, hold the WPL Reset and Network Reset buttons for 10 seconds. Light will turn solid red for 10 seconds. You need to reset both 50s this way.
After this is done, you should see both the Core and 50s available to setup in the app.
I have seen some 50s not like to connect to wifi this way – you may need to connect to the 50s wifi network that is broadcast while awaiting setup. Then, set up in app, go to settings>config to add to your home network.
