Home › Forums › Product Discussion & Questions › BeoLab › Beolab 5 tweeter playing low volume
- This topic has 3 replies, 2 voices, and was last updated 1 year, 2 months ago by
DanteM.
7 January 2025 at 02:42 #62373
DanteM
BRONZE MemberAnyone experienced a BL5 playing low volume only on the tweeter?
Lower bass, mid bass and midrange are OK, just the tweeter is playing low.
I have checked the impedance and it is OK at 3.0 Ohm. Also checked the NTC temperature sensor and it is ok at 470kOhm 25oC.
Any other ideas?
7 January 2025 at 12:40 #62384LeHe
BRONZE MemberHave you activated the automatic recalibrated system of your speakers so that the power amplifiers set themselves to the correct power value using the internal software circuit in relation to the speaker microphone. If the calibrated system detects troubles in the hardware it wil let you now with led colors so I read in the user manual.
8 January 2025 at 14:30 #62405LeHe
BRONZE MemberI read in the service manual that the tweeter impedance should be 6,6 ohm and not 3 ohm as you specify as good !
11 January 2025 at 02:25 #62516DanteM
BRONZE Memberhumm…interesting…
The document I found on the internet mentions on page 15 the impedance of 5.7 Ohm for the midrange and 3.0 Ohm for the tweeter. Furthermore, just to record here, 3.1 Ohm for the lower bass and 5.0 for the upper bass. NTC sensor 470k Ohm @ 25oC.
Anyway, i just found out that the problem resides in my Beosystem 3.
I changed the powerlink port and the problem was solved. I don’t understand why…
