Home › Forums › Product Discussion & Questions › BeoLab › Beolab 5 flashing red
- This topic has 1 reply, 2 voices, and was last updated 2 years, 4 months ago by
KHX.
28 October 2023 at 12:21 #49886
Frog
GOLD MemberMy pair of Lab 5s, when driven hard (say watching Top Gun:Maverick) both start flashing red after an hour or so – they are fine when used at normal listening levels.
the manual suggests that the temp sensor is cutting them out, but what I find odd is that both speakers disconnect and starts flashing at exactly the same time – it’s unlikely they are both at the same (hot) temperature at exactly the same time.
I suspect something else.. I haven’t calibrated them for quite some time as the room shape nd contents haven’t changed, and am loathe to do so as I hear there is a finite amount of times you can do this.
has anyone seen anything like this – I know a chassis change is possibly on the cards, but maybe there is a simpler fix for this odd behavior.
30 November 2023 at 08:03 #49887KHX
BRONZE MemberI haven’t calibrated them for quite some time as the room shape nd contents haven’t changed, and am loathe to do so as I hear there is a finite amount of times you can do this.
Say what? Is this really the case, that the calibration process has a limited number?? :O
