Home › Forums › Product Discussion & Questions › BeoLab › BeoLab 5
- This topic has 3 replies, 3 voices, and was last updated 3 years, 6 months ago by
Millemis.
2 September 2022 at 09:20 #38797
Henry
BRONZE MemberHi all, I’m moving home and 90% decided on purchasing BL5s. Will I be able to use a digital signal for them from my BV10 46? Cheers
2 September 2022 at 09:40 #38798
NQVHNWIBRONZE MemberHi,
IIRC, (50:50) the BV10 has only an SPDif Input. No audio digital ouptput. Thus, the BL5s can only be fed via powerlink.
If you are using the BV10 as a Master and have say a BeoSound5 in the setup via Masterlink, then you can connect the BS5 SPdif output to the BL5. However, you will still need to connect the powerlink from the BV10 to BS5 for volume control.
I was never convinced, but you can also continue the SPDif/Coax out of the BL5 to the BV10 SPDif input in a closed loop. This in theory should give optimal sound from the BS5/BV10 if you choose (for any bizarre reason) through the centre channel.
As above. 50:50. You may want to ask a friend for an alternative answer.
5 September 2022 at 16:01 #38799Henry
BRONZE MemberCheers mr10%
In which case it might also be time for me to update my BV10 46 to something newer so I have digital signal out to BL5s. Harmony is tempting but pricey.
5 September 2022 at 19:18 #38800 Millemis
BRONZE MemberMy “alternative” answer would be….…
…….choose the Beovision you like (or the BS Theatre once that is released) and just use the Powerlink connection.
There is no BV solution with a SPDif output!
