Home › Forums › Product Discussion & Questions › BeoLab › Beolab 4000 switching itself on
- This topic has 5 replies, 4 voices, and was last updated 3 years, 8 months ago by
Ray Dahr.
23 July 2022 at 09:53 #36316
Ray Dahr
BRONZE MemberHi everybody, I’m a new member here with a Beo problem. I have a pair of Beolab 4000 MK1 active speakers. One of them has started to constantly switch itself on from standby and hum, without an audio input signal. It does this with or without the audio cable plugged in, with different power cords and power outlets. Any suggestions what may be the cause?
Thanks for any clues.
24 July 2022 at 17:13 #36317
kirinBRONZE MemberHello, my experience was unfortunately, that this is a beginning of the end of a a beolab 4000 speaker due to the foam-rot issue, just search the archive forums for „Beolab 4000“ and „foam“. These damping materials inside the Beolab 4000s are getting old and sticky and etch the PCBs to death. Resulting in the case that Beo4000’s do not switch on any more.
BTW, did anybody manage to repair them?
Best regards
24 July 2022 at 20:13 #36318Ray Dahr
BRONZE MemberThank you for your reply. My speaker has the white foam, there is no visible deterioration of foam or boards.
There is no problem switching it on. Quite the opposite, the problem is that it constantly switches itself on while in standby, with or without an audio signal, with or without an audio cable plugged in. It makes an annoying hum after it switches itself on.
25 July 2022 at 10:26 #36319 spassmakerBRONZE MemberHi
As you wrote that there is a white foam inside , it might be that teh foam was already renewed from a preownwer.
Could be that the old foam was not removed completely from the PCB’s and now the rest of the old foam did his work.
Inspect the PCB for unusual colours of the traces and parts.
Kind regards
Christian
25 July 2022 at 11:05 #36320Die_Bogener
BRONZE MemberClean the manual switch, it’s oxide and old grease … L … R … Auto
Use the switch, many, many times…
25 July 2022 at 19:06 #36321Ray Dahr
BRONZE MemberThanks for the suggestions.
The boards in these speakers look as new, no discoloration, no deterioration.
By swapping boards with my good speaker I have determined that the problem is not with the board that has the switch on it.
