Home › Forums › BeoWorld around the world! › Deutsche › Beolab 3500 does not work in Masterlink
- This topic has 13 replies, 3 voices, and was last updated 2 years, 8 months ago by
Madskp.
10 July 2023 at 12:09 #47566
krimmth
BRONZE MemberHello B&O Community,
A couple of weeks ago I bought a BL 3500 MKII in mint condition.
Last weekend I tried to connect to my existing masterlink system with a BS 9000 in the main room.
After connecting the BL 3500 to power and masterlink the display shows only dots. What means the timer led indicates that the timer is set to on. No clock and the standby led was also on.
I pressed timer to set timer to no. However this will not work as described in the manual.
Does anyone have an idea why I cannot switch off the timer.
One other thing I have in mind, could it be that the previous owner changed the electronic to work as soundbar? Would this be the behavior?Thank you for your support.
10 July 2023 at 12:42 #47567Madskp
GOLD MemberI don’t see you mentioning if you can play music from the BS 9000 on the BL3500, but the subject suggest that you can’t?
One thing to check for first if is Masterlink is enabled on the BL3500 by pressing
Menu, menu, 0, 9, GO with a BEO4 remote. Then you should be able to choose ML on or off with up and down arrows.
If it is on you can also check the ML status by pressing Menu, menu, 0, 2, GO
This will either show: NO ML, ML OK or an error 1-4.
Let me know what you findings are
11 July 2023 at 15:39 #47568krimmth
BRONZE MemberThank you! I found the issue. Connected the Speaker to another Room. Works as expected. Seems I have a problem with the wiring in the junction box from where the cable goes to the place of the BL 3500.
11 July 2023 at 17:26 #47569Madskp
GOLD MemberGood to hear that it is working now.
Always nice with an easy fix.
12 July 2023 at 07:27 #47570Madskp
GOLD MemberBtw could I ask you to check the software version of your BL3500?
It is done by pressing menu, menu, 0, 0, GO
I have another thread where I am trying to find out which software versions that has been available, so just to see if there are some version that I don’t know of.
Thanks in advance
3 August 2023 at 17:51 #47571krimmth
BRONZE MemberTook now a couple of weeks to dive deeper in my installation.
I am not sure but I believe I faced an issue with my masterlink wiring. Unfortunately I have the cables in wall.
I have mixed the old ML world and new NL world by connecting with a ML/NL converter.
I bought a cable with a ML plug on one side and a RJ45 plug on the other side. Thought it would be good to connect to the converter.
Cut this cable into two halfs in order to have to ends for connecting my devices and used a junction box to connect all 4 devices.
The rooms with the standard old fashioned ML cable (9 wires) working perfectly, what means the BS 9000 delivers sound to the bathroom.
The devices (BL 3500 and ML/NL converter) connected by the cable with the ML /RJ45 plugs are not working.
The CAT7 cable provides only 8 wires and the ML cable provides 9 wires. I know the white / blue wire is bridged with the pink one.
Could it be that the ML sense is not working without all wire on the dedicated pins.
The BL 3500 shows no reaction (in the bathroom it is working properly) and the converter shows also no reaction.I hope my english is good enough that you understand my concern. 🙂
3 August 2023 at 19:01 #47572Madskp
GOLD MemberThe CAT7 wire should have a shield that according to the Beolink Handbook should be connected to the three solid blank wires in the ML cable. This is the 9th wire.
hope this will help you
3 August 2023 at 19:03 #47573krimmth
BRONZE MemberThank you for the hint! The shield is not really connected to the blank wires. I will try to connect and give an update.
3 August 2023 at 20:36 #47574krimmth
BRONZE MemberUnfortunately it was not the resolution.
Must anything wrong with the cable and plugs or with the junction box.
Checking the ML status I got the error code “2”.
For masterlink to work, must pin 3 and 12 be connected to the masterlink plug?
3 August 2023 at 20:42 #47575Madskp
GOLD MemberFor masterlink to work, must pin 3 and 12 be connected to the masterlink plug?
Not quite sure I understand what you mean.
Pin 3 and 12 should be used in the masterlink plug end, but in the Rj45 end they can be spliced toghether.
You can see the pinout in the Beolink Handbook 1.9 at page 98 https://beoworld.org/beolink-handbook-version-1-9/
3 August 2023 at 21:07 #47576 MillemisBRONZE MemberWhy not just use a regular ML cable?
Plug in the ML connector to the converter and run the ML cable (without the ML plug) to the junction box and mount the wires there just like the other ends are.MM
4 August 2023 at 07:32 #47577krimmth
BRONZE MemberYou are right, usually I should change the cable. However the cable is in the wall which is plastered. I will measure the wires at the end of the ML plug and check if pin 3 and 12 are connected.
4 August 2023 at 09:38 #47578krimmth
BRONZE MemberGuys, unbelievable, I found the issue. Thanks again for the hint with the newest version of the Beolink Handbook v1.9.
I referred to the v1.5 handbook which I have saved a couple of years ago on my computer.The RJ45 / masterlink pin occupation is on the RJ45 side wrong described. See the attached picture.
After I have changed the sequence all my problems are solved. The BL 3500 is working and my ML/NL BLC is working perfectly.
4 August 2023 at 09:40 #47579Madskp
GOLD MemberGreat to hear that you have solved it 🙂
