Home › Forums › General Discussion & Questions › General Discussion & Questions › Solved: Beolab 3000 and BV7-40 mk5 compatibility
- This topic has 0 replies, 1 voice, and was last updated 4 months, 3 weeks ago by
pepps.
22 September 2025 at 14:27 #69837
peppsModeratorI answered my own question by reading the manual – gold member perk. I’m also taking myself for a long walk off a short pier for being so stupid.
So there’s a switch on the side of the Beolabs for setting audio or video for the displays.
I might be placing an oder with Steve for another fully wired l-o-n-g PL cable to finish my set-up
Annoying how the PL cable I bought from B&O works with my Pentas but not the BL3000s.
Anyway, all is solved.
Hello,
I recently bought a fabulous Beocenter 9500 and a pair of Beolab 3000.
The seller kindly included all cables and demonstrated the system to me – all in tip top working order.
I drove home and set up the BL’s as rears connected by the same supplied powerlink cables to my BV7.
A hum emitted from one speaker and no display action at all.
I connected the BL’s to the 9500 and they worked perfectly again.
I’m curious if the displays can work while connected to a BV because there isn’t a switch on the rear to select ‘audio’ or ‘video’.
I have experimented with 3 different cable types: 1 from B&O dealer in Canterbury (since closed) which was a fully wired cable I use normally to drive my Pentas. 2 from Steve at Sounds Heavenly – a fully wired cable I also use to drive my Pentas. 3 the cable supplied by the seller.
All 3 cables will send music and display data from the BC9500 to the BLs but I can’t get displays working from the Beovision.
One thing I have not yet tried is to daisy chain the Pentas and the BL 3000s and run them from a single PL socket on the BV.
Would that even be possible?If anyone can confirm if displays do or do not work with a BV7 that would be a start. Any other advice to help solve the problem will be gratefully received 🙂
Favourite Product: Beosystem 6500
