Home › Forums › Product Discussion & Questions › BeoLab › Beolab 3000 / 4500 / 5000 question
- This topic has 4 replies, 2 voices, and was last updated 11 months ago by
Madskp.
27 April 2025 at 22:40 #65360
CharlieWednesdayGOLD MemberQuick question – the Beolab 3000, 4500 and 5000 panel speakers – is the amplifier/display unit the same for all three of these models, or do they differ?
28 April 2025 at 06:09 #65361Madskp
GOLD MemberThe 4500 is an updated version of the 3000
Look here https://beocentral.com/beolab4500
I am not sure if display colors are different like on the Pentas (yelllow vs green)
28 April 2025 at 06:12 #65362Madskp
GOLD MemberThe displa colors are mentioned here https://beoworld.org/beolab-4500/
I guess the 3000 and 5000 share the same display
28 April 2025 at 11:35 #65364 CharlieWednesdayGOLD MemberAh, interesting, thanks. Reason I ask, I’ve just bought a job lot that includes 1 pair of BL3000 and 2 pairs of BV4500, I was wondering if I should switch the amplifier component from the 3000s onto the 4500s, to make a pair of BL4500s instead. Not sure it’ll be worth the bother though.
Also I’m colourblind , so the difference between yellow and green displays will be lost on me!
28 April 2025 at 17:36 #65366Madskp
GOLD MemberI was wondering if I should switch the amplifier component from the 3000s onto the 4500s, to make a pair of BL4500s instead. Not sure it’ll be worth the bother though.
Maybe check if the speaker foam looks ok on both of them. But other than that probably no other reason than scratches and fabric wear that could be issues
