Home Forums Product Discussion & Questions BeoLab Beolab 3 Power Supply Schematic
Viewing 6 posts - 1 through 6 (of 6 total)
  • #67968
    tommaso.vercesi
    Hello Beoworld, I’m working to fix one of my Beolab 3.
    Power supply is gone, problem is likely in the area in the picture, where you can see few components are burned.
    Of course fuse is blown now.
    Rectifier and few capacitors replaced, but were likely ok.
    • Do anyone have a schematic for this power supply (A6143262 Ver G) ?
    • Or, do you know what are the components ?
    Thanks for help.
    #67983
    Madskp
    GOLD Member
    Hello
    The servicemanual for Beolab 3 only have block diagrams showing the connections between the boards, no component level schematics.
    Your best bet might be to compare to the components in a working one, provided you have 2 Beolab 3 speakers
    #67997
    tommaso.vercesi
    Hi, yes, I’m aware about it. It is a bit weird because it is marking power in on P1.1 and P1.2 while it is on P1.1 and P1.3.
    Other than that, it is useful but not enough. Yes, I can use another power supply but I don’t like the idea to remove the components to measure it.
    I hope to find a schematic and do it better.
    #68764
    Nima Ghassemi
    can someone give me ordering partnumbers for the 2 rifa x2 Capacitors and the 2 red Kaschke coils ?
    my Beolab 3 started to smell burned.  The 220nF X2 is fully blown and has also damaged the 2 Kaschke coils. I already removed them from the pcb but I cannot identify much. In order tobe on safe side, I also would like to replace the 100nF X2.
    is there any further recommendations to replace other parts in order to be on the safe side when the x2 blows up ?
    million thanks in advance!
    #69239
    Alvaro Aguilar
    I replaced the capacitor in mine. I have an extra one I can send you if you are in the US. Otherwise the PN is: PME271M622KR30.
    Have you been able to find the replacement of the Kashke coils? I’m still having an issue where the speaker starts making popping sounds after been in standby for a couple of hours and heats up. This led to blowing out the capacitor initially.
    #69669
    Nima Ghassemi
    Yes, I was able to find everything.
    Kashke has been aquired by Bourns. I contacted Bourns but their service does not really want to help – not even with datasheets. Then I found PMEC. As for Kashke 049.752, this is the direct replacement:
    PMEC 102/Ve 18m 1,0 A
    https://shop.pmec.cz/index.php?page=details&cat=2&prod=1062&alt=102/Ve%2018m%201,0%20A
    Kashke 049.769 is a customized component – which does not exist. But I sent mine to PMEC and Josef from PMEC did all measurements and they could produce a replacement for me. Technically, it’s
    102/Ve 18m 1,0A, too but it has some isolation and the winding is reversed. If you need this choke, I am sure that they will also produce this one for you.
    Therefore, if you need any Kashke parts, I can highly recommend you PMEC as this company is specialized on these components and the support I received was impressive!
    As for the 2 X2, these are the partnumbers. PME27MD6220KR30 and PME271MB6100MR30. I ordered them through farnell:
    Attached, you can see the new parts – including the 049.769 one with the isolated pins (yellow isolation).
