Home › Forums › Product Discussion & Questions › BeoLab › Beolab 3 no light- help!!
- This topic has 6 replies, 4 voices, and was last updated 1 year ago by
Victor Po.
28 November 2023 at 05:11 #50841
Acalvadesh
BRONZE MemberHello all! It’s Andrew calvadesh
I have a Beolab 3 that came out of storage and now it doesn’t work!! ? when it’s given mains there’s no indicator light at all. Can anyone advise on what might be wrong. Does anyone have PCB I can buy? I’ve looked at it disassembled already but there’s nothing burned or visibly damaged.
thank you so so so much!
30 November 2023 at 19:33 #50842 BeobuddyGOLD MemberIt happens regularly. The powersupply then fails. Most are repairable.
A dealer can send the Beolab to DK for repair. If there isn’t one nearby, you can send it over to me.Location: Utrecht
30 November 2023 at 20:09 #50843Acalvadesh
BRONZE MemberHello!! Thanks for your comment. I’m going ahead and replacing the fuse and the two main capacitors Because it seems they are the problem.
I’ll let you know!
thanks
8 December 2023 at 01:37 #50844Acalvadesh
BRONZE MemberHello!
so update to the whole post: I fixed them! It was the main capacitor on the PSU. Now the only problem is one will randomly stop producing sound (with green light still on) any ideas? Big problem is solved thankfully.
15 April 2024 at 23:10 #50845mekkararamesh
BRONZE MemberCan you post images of PCB with whatbfix you did?
Also, can you detail the capacitor type and where you sourced the parts from
13 February 2025 at 05:27 #63763Victor Po
BRONZE MemberWas it the big blue capacitors?
You must be logged in to view attached files.13 February 2025 at 05:29 #63765Victor Po
BRONZE MemberOr was it the large black ones?
